Discuss Maxipod (domestic heating issue) in the UK Electrical Forum area at ElectriciansForums.net
Hi folks ,
I’ve been asked to take a look at a domestic heating problem , I’m hoping to get a bit of advice so I have half of an idea of what sort of issue i’m looking at ..
basically the guy has put in a maxi pod . Don’t know much about them other than it gets a permanent feed to the cylinder stat and it calls on the boiler to heat the water continuously.. the problem is that when the stove is lit , the maxi pod is still calling the boiler for heat , even when the stove is roasting hot .. at the minute the only way around this is to turn the cylinder stat way up and turn the pipe stat coming from the stove way down , any advice on how to remedy this ?
Again I haven’t had much of a look at it , just briefly when i was in doing other work .
Thanks in advance
Have you done anything with Maxipod's before?
Is it gravity fed from the stove or pumped (guessing pumped given pipe stat)
Been a while since I worked with one, I should have a wiring plan for them, I'll see if I can fish it out
Just asked the question and it is gravity fed . Although there was definitely a pipe stat when I had a brief look at it .
A wiring plan would be great if you could find it .
Reply to Maxipod (domestic heating issue) in the UK Electrical Forum area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
