Discuss megger 1720 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi,
I have a mft 1720, the equipment itself is brilliant but every so often when I test earth loop impedance the rcd trips before it gets a zs value. On the same system I tried a older mft and got a zs reading straight away. Any suggestions
I have one too and have had it happen .
Tbh I think it only happens when I make a bad connection with the leads ( when i dont have enough thumbs) or when the terminals I'm probing onto have a bit of lacquer on.
I have not had an instance where I could definitely put the blame on the meter.
I would say that the tester is trying to use a higher current to test and is running the test for longer to eliminate errors due to voltage shifts during measurement and therefore, if there is even a bit of leakage on the existing installation this may push the RCD into tripping.
Reply to megger 1720 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
4K
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
