Goody
- Reaction score
- 94
I have a “MAGNUSS” CU with a single RCD and the meter tails are 16mm (main fuse is 100A).
For a newly built partition I am adding a new ring with two double sockets and connecting it to a 32A MCB on the CU. I am going to present this as a “Minor Job” for my assessment. Because the CU isn’t a split one and the tails are only 16mm, would this raise any question during my assessment?
Other than Ze, Zs at the sockets, ring continuity, IR, r1+r2, r1+rn and RCD tests, is anything more needs doing.
When the assessor checks the work, should I safe-isolate the whole CU or just the circuit needed isolations and locking. What sort of questions should I expect on this when I get assessed?
Many thanks!
Many thanks!
