Discuss Minor Works cert in the UK Electrical Forum area at ElectriciansForums.net
robo83
Hi,
I have been in discussion with a friend Regards minor works certs for a couple of jobs he did recently.
1. Move light (cable is not extended just moved 300mm using slack in loft)
2. Change single socket to a double socket.
He has insisted he is not altering the circuit and that it is classed as more maintenance based.
What's your thoughts on this please.
Hi,
Bull poo, you have altered a circuit MNWC, your mate is he an Electrician?
He is yes, this is what I said to him. He has said how is the light removed then put back up minor works when it's no different to a maintaince task.
BYB gives some suggestions for the use of a minor works, including the relocation of a light switch, replacement of equipment such as accessories or luminaires.
Quite frankly though, if you did that every time for such small works, you'll spend more time testing than actually doing the work. Depends on the circumstances, and what the customer wants IMO.
I think you need to apply a dose of common sense..... the people that write the regs believe you should do a MWC even for a change of accessory.. but I don't ..... a note of the Zs on the invoice is more than adequate IMHO
Look how much of a problem will it be to issue a MNWC? just do cut all the BS people are always going to argue this issue, do what you think is right far to many people sticking their oar where it's not needed imo.
The only thing is, there's a few bits and pieces to record, even on a MEIWC. If your not going to fill those details in, what's the point of issuing one?
Whats the points of arguing the issue? issue the cert stop faffing around over something that is not that important anyway FFS
Ok thanks.
So if these tasks do need a cable extending. Or a spur added and the bonding is inadequate or undersized.
Is it permissable to note this on a MNWC?
Ok thanks.
My thoughts are that any diligent electrician would have assessed the system for suitability and safety before alteration and tested both circuits for safety when carrying out these tasks. It's no big shakes to record those results on a MWC, needed or not.
If your 'mate' was not doing any testing or issuing a certificate how is he ensuring that what is already there is actually okay, we seem to be working on the assumption that everything is fine.
Seems a bit hit and hope if you ask me, all okay until some poor customer or worse still their young child is electrocuted and you are subsequently gripping the rail and trying to explain to the nice man in the wig why you couldn't be arsed to test!
No doubt someone will tell me I am being over dramatic, but no one actually sets out to kill someone, but it still happens!
To me it's the same as removing an existing light fitting and replacing it with a ceiling rose? I did this last week in a house and moved it about 150mm using slack in the loft. Checked the earth was good, classed it as maintenance so no cert issued. The fitting I replaced was a bodge anyway, rawl plugs barely holding it to the ceiling, wires twisted together wrapped in a bit of insulation tape.
With the socket I would test and issue a MWC.
Reply to Minor Works cert in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Morning all. I was chatting with another spark the other day and he’s telling me I’m making excessive work for myself by issuing minor works...
