Discuss Mounting on top of insulation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
He was an architect, so I guess he knows what he's doing.
I've seen this once before but the insulation was sandwiched between some sort of rigid sheet - can't remember what it was but fairly sure it wasn't wood.
Have you considered integrated panels or solar tiles? I guess an architect's into his technical drawings and appearance of buildings so he might prefer the look. It would be an interesting project for the installation team as well working with different components. Not sure about the cost element but if he's planning to re-roof anyway it might save on labour. materials and weight.
about half of what an Architect designs would fall down if it was ever built!
You know what RIBA stands for don't you, Remember I'm the Bloody Architect!!
I suspect what his is intending to do wouldn't pass building regs. The battens are only there to stop the tiles sliding off. the main structural support is from the rafters. If he puts a non ridgid insulating layer between the rafters and battens then over time his roof will sag under the weight and go all wavey!! The strongest part of his roof will be your rails!!
Are you sure he isn't intending to insulate between the rafters themselves, not between the rafters and battens?
I have also seen kingspan and celotex fixed on the underside of rafters and then plasterboard for loft conversions and open ceilings.
yes, thats common practice, but thats not the same as insulation between the rafters and the battens!
If this is what he intends doing I think he has been sniffing something!!
The design you are referring to is called a warm roof, it is becoming more common in new builds as it is much easier to ensure consistent insulation detailing. (also a damn site easier to fit down lights in between rafters when there is no insulation!)
As Solarsavings says you can fix through the counter batten with a really long fixing to pick up the joist behind, or if you have sufficient batten size and a structural engineers approval you may be able to just fix to the counter batten.
Saw this being done to buildings outside the Iona ferry point, King span fitted over wood cladding, then battened, then slated re,fitted. Could be a tricky one to fix to due to the standoff distance between solid components, and may need to fix noggins and through bolt....speak to the architect!!
The counterbattens run down directly over the rafters and are in effect sandwiching the insulation board and so once you have pre drilled and screwed all the way through the counter battens into the rafter you then have virtually no compression of the insulation. You have to remember that counterbattens are already going to be taking the load of the tiles and so are able to take a large load without the insulation compressing. This is fresh in my mind as the guys on site have got one to do tomorrow, out of all our jobs I reckon we have only done 2% warm roof installs so it either shows how few newbuilds we do or that the customers that have PV live in older houses!
I was going to say superglue or runaway, never seen it myself but some good replys on here..
I have seen it done like this on several jobs (insulation on top of rafters), mainly barn conversions and the like. It isn' a particularly good idea IMHO but thats by the by, we used to drill a 20mm hole through the insulation to the rafter, and drop in a peice of 20mm conduit cut to the thickness of the insulation, then screw the brackets through the conduit and into the joists with sheradised screws.
Need to ensure you've got square cuts on the conduit! I guess need at least 150mm long screws, longer if insulation greater than 75mm!
Isn't the conduit is also being stressed by the bracket being clamped directly on top of it!
we had got some stainless tube cut to length by local firm. very cheap. gives the bracket something to tighten to when the insulation is poorly installed or too compressible.
Reply to Mounting on top of insulation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
