Discuss Multimeter Help Please in the DIY Electrical Advice area at ElectriciansForums.net
Can anyone tell me if the two probes are plugged into the right sockets so I can measure the amps on my heated motorcycle grips? Also which setting do I need to put the dial.
Once I get that bit sorted how do I then go about testing my heated grips on my bike?Multi.JPG
Plug the red lead into the 10ADC socket. To measure amps select 10A on the meter dial, connect the negative wire from the heater grips to negative of the battery, connect the positive wire from the heater grips to the black lead from the meter. The red lead from the meter connect to the positive battery terminal.
Reactions: DPG
I would first try and take a resistance measurement of the grips. That will do two things... 1) tell you whether they are likely to work and 2) give you a value that you can use to work out whether you're likely to blow up your multimeter trying to measure the current they draw.
Reply to Multimeter Help Please in the DIY Electrical Advice area at ElectriciansForums.net
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
Hello everyone, friends. In cases where I do not have a clamp meter, I want to measure the current drawn by the phases of a 3-phase motor with my...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
