Discuss Multimeter suggestions in the Electrical Tools and Products area at ElectriciansForums.net
gazdkw82
I'm after my first quality multi meter. I'm thinking preferably one with a clamp function on it.
I'm not bothered about brand as I have no real experience (although my fluke voltage tester failed just after 12 months)
Which one I choose will be based on price, functions, reliability and warranty offered.
What suggestions??
Thing is I don't want to be carrying loads of different tools around with me. I will most likely be starting a new role based around maintenance so I'll be carrying a backpack around. Space will be limited. What's the difference between a clamp meter and the meters with the cut out? Assume it does the same thing just different style?
Some fluke multimeters have a clamp accessory that you can buy as an addition, i get more use out of my multimeter than my clamp meter. Just leave it in the van if your hard on space.
Clamp meter measures high current as well as standard voltage / resistance etc.
Take a look at the Amprobe 220 EUR, excellent bit of kit & not heavy to carry. Best thing I've put in my service bag in a long while.
my amprobe. (circa 1965):
Why would you be pulling different meters out ?, are you measuring anything other than the usual Amps, Ohms & Volts ?.
it's a pain trying to measure Amps with a mutimeter. first isolate, disconnect conductors and connect to meter leads, then re-energise, measure current. then repeat procedure to reconnect.
No just the usual amps, ohms, volts
That was why I suggested a clamp meter, the 220 for example is True RMS & will do 600v AC/DC, 6/60/600a AC/DC, 60K resistance & 2500uf capacitance.
Also has a non contact tester in the tip.
There are plenty of other makes / models that provide the same functions, the reason I prefer the 220 is that it's pretty compact.
Reply to Multimeter suggestions in the Electrical Tools and Products area at ElectriciansForums.net
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Megger MFT Deal!! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers – MFT1711, MFT1721...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
