Discuss Name of Device being used? in the Industrial Electricians' Talk area at ElectriciansForums.net
I think we need to know what it’s connected to electrically, and it’s function.
The symbol on it describes what sort of valve it is, but it’s too blurry. Another photo would help.
It won’t matter if it’s pneumatic, hydraulic or a beer line….. it has a function, and with only 3 ports, I’d suggest a changeover valve (like a two way switch)
The tubing is connected to a blower or vacuum unit into the single opening and then run into an air pressure sensing switch with an an adjustable set point. One of the tubes is connected to the the low and the other the high.
Yeah it's a pneumatic valve. Can you post a better photo so we can make out the symbol printed on it.
Thanks for identifying the device. Wish I had a better picture, its from a video with low res. Here is another image of the device from a different side, thing that might help is there is a red dot on the side of the device.
It's a changeover valve. You can just make out the arrow symbols,in the first picture,which show direction/port connection,in it's actuated and at rest position.
Match it correctly,as some have exhaust facility,some not.
Looks like a pneumatic solenoid valve. It is used to direct or stop the flow of compressed air in a pneumatic system. Sometimes called a directional control valve, they are used in automation and control applications to actuate tools
Reply to Name of Device being used? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, We have a HV Schneider GenieEvo breaker, on the name plate, this device is rated for 50Hz. What would happen if we used a 60Hz supply...
Hi, Bought a MainsSwitch device to run the RF pairing link to switch some low voltage LED strip lighting under my Breakfast bar. No direct switch...
Hi everyone I bought the following device for the purpose of inspection and testing of DPs and its connecions...
With AFDD's still being a widely discussed topic, we have put together a guide that either you or your apprentices may find useful! Electrical2Go...
Hello, I need to conduct interviews with experts in the relevant field for my university project. The topic and product that I’m developing a...
