Discuss Need help switching out some 12v lighting in the UK Electrical Forum area at ElectriciansForums.net
Cdm990
Hi I am having a problem with my bedroom and bathroom lighting ,in my bedroom I have 2 downlighters that are switched from 2 dual pole switches at either on of the bedroom,these downlighters are 12v fed from a transformer in the loft ,I also have 1 mains light on my ceiling too,I'm wanting to remove the 12v and connect up more mains downlighters to the ceiling light ,however I can't understand how this is all wired . I've attached a picture of the transformers what I'm wondering is if I disconect the transformers and connect the outgoing cables to the mains incoming will the switches still switch the new non 12v lights on
Looks like the CPC has been cut in the outgoing ways to the 12v lighting.
You will need to rewire from the 230v mains in and carry on the circuit to your desired locations.
Reply to Need help switching out some 12v lighting in the UK Electrical Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi, I want to put downlights in my fire surround - possibly 3 but more likely going to be 2. They are 0.4w LED lights. I have a 12v 8w LED driver...
