Discuss New flat supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J.C.E
Council block of flats
Ryfeild board in ground floor intake (60a bs88 fuse)
flat is directly above intake 2 floors up- but flat fuse board and meter is in middle of flat (not by front door)
Is it ok/ good practise for installing a new supply like the following:
3core 16mm SWA XLPE from Ryfeild (through the 2 floors cleated to the wall in communal area) run approx 10m
Then made off into a metal adaptable box outside the flat front door
using 16mm through crimps covered with heat-shrink
then from this point- 16mm double insulated tails and 16mm G/Y single core in plastic mt4 surface along the hall inside the flat approx 8m run- to the meter and board.
cheers.
cheers.
Have you not thought about moving the board and maybe meter moved?
Is it landlords meter or power companies?
(As it is surface it doesnt need rcd protection so it is allowed)
Thanks for quick reply.
L/L responsibility
its not my job or a future job etc
its how my company I work for have been doing a few flats recently.
i thought a isolator would be needed due to lengthy run (or is just the fuse in the ryfeild sufficient?)
L/L responsibility
If you do put an isolator in next to adaptable make sure it can be locked on or off. Otherwise someone might use it to tap in before meter.
And give key to landlord not tenant
Anything before the meter is.........unmetered and therefor subject to security.
You should have no access to the Ryefield as it should have a DNO padlock on it.
Boydy
Reply to New flat supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi all Called to do an EICR on a property 4 studio flats / bedsits within a single house. The t&e sub main to each flat runs within the fabric of...
Hi all, quick question - I have to replace a lateral supply cable where the existing one runs through the ceiling of the basement flat and up...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
