I
iamelectric
installing new shower just shower unit no new wiring involved , old house no rcd protection , i need to install an rcd for new shower correct?
Discuss new shower in the UK Electrical Forum area at ElectriciansForums.net
is this true?Unless you can run surface / mechanically protect etc, then you do buddy. You can get shower RCD units fairly cheap though to be honest.
indeed not...I have to say I wouldn't be fitting a replacement shower without a RCD. manufacturers instructions or not!
Fair enough.Cable all covered in insulation in loft then boarded over, she didn't want it disturbed
what's wrong with 9.5kW on 6mm 40A as long as it's ref. method C?
Reply to new shower in the UK Electrical Forum area at ElectriciansForums.net
