J
Jimmyb
Why is it the hallway and some switches seems left out on earths in so many houses, i mean no earth wire within the cable for them but most of the house wired in t&e or ive found where they just have bothered with connecting the earth is there a reason for this
Was this wire ever legal stuff ? and is it just lazyiness when they havnt connected it ?
What is it vir? Tinned stranded? Copper stranded? early single core pvc sheath?.......all were to regs on the edition that they were available (but possibly not when installed)..lol....
Houses prior to 1965 were 13th edition I think which meant no CPC on lighting circuits, bit of a pain now but does not always mean a rewire. there was a good thread on this a couple of days ago - lighting circuit no cpc
Not 13th (well into 70's). Domestic lighting required cpc. Threaded steel conduit sufficient.
Just means no class 1 lighting (metal) Unless of course you can get a cpc back to the board..............
Reactions: 1 person
This has reminded me of a bodge I did a few years ago on my flat... Converted 1 way light to 2 way light using the cpc as an extra core...
How's the best way to fix this one now I've trying to do everything "properly"?
Run a separate 3 core between the switches and reinstate the cpc.
Reactions: 1 person
single/double/triple core pvc sheath, they must of had it left over hence why a mix of both t&e and the others, but i always find it on landings and sometimes upstairs, there must of been a lot of house wired just at the change over point lol
yer is a pain now when i tell the customer they need to replace the metal fitting or rewire and i get its been ok for the last 20years
please tell me u didnt forgot the sleeving and not to cut it too short
What I have also come across (other than borrowed neutrals), is two lot's of T&E with the neutrals (blacks, old colours) doubled up as the common strapper in place of three core and earth, I guess they had no three core!, Iam not sure if this contravenes any regs though ?
If they knew a cable type was goin to be phased out i reckon they would sling it in for all they were werth but dont forget that when we went onto new colours there was a transitional period.........places like orange shed were tryin to knock it out an the cheap as they had too much of it in stock and had to get shut of it before the deadline.....it was probably the same back then...............
What I have also come across (other than borrowed neutrals), is two lot's of T&E with the neutrals (blacks) doubled up as the common strapper in place of three core and earth, I guess they had no three core!, Iam not sure if this contravenes any regs though ?
As long as the conductors are correctly identified with sleeving (red in those days) and the cpc hasn't been used for anything else, no.
No earths on some many houses.
Australia
Jimmyb,
topquark,
