Discuss No fusebox or consumer unit? in the UK Electrical Forum area at ElectriciansForums.net
kevwright
Hi, new here just a bit confused about the electrical supply into our rented house and wonder if I can get some advice before speaking with my landlord?
I thought all houses had a consumer unit or at least an old fusebox?
All we seem to have is this in a cupboard under the stairs!
The daft thing is, we have lived here for 20 years, and have never had a fuse blow!
Thanks in advance.
Hi Kev,
You might find there are 2 fuse (ceramic/re-wireable) behind the cream cover.
It is technically a very 'basic' consumer unit providing power and lighting circuits (probably no cooker)!
Hi Kev,
Thanks, so we do have a cooker of course, wonder how that is wired in?
Reason for asking is that we want to have an electric shower fitted so I guess we are gonna need a complete new consumer unit fitted first?
Kev
How old is the property? Have you ever been n the loft if it has one?
That looks like it could be an old style switch fused isolator, and your DB is in a remote location from the dno supply head,
Turn it off and open it up and have a look inside,
You could just have a dedicated shower board fitted and leave the existing BUT.
There may be other issues to consider though such as earth bonding as cant quite make out an earth connection in the photo.
Looks like a 'pipe clamp' on the lead sheath of the supply cable but where does the g/y cable go?
It goes into a hole in the floor!
Kev
[automerge]1570137218[/automerge]
Thanks, will prob get a proper sparky in to have a look I think
Kev
If you have been there for twenty years has there ever been an electrical safety check?
The cream unit is certainly your consumer unit. The fuse holders are located under the cover.
It would be best to have a new one fitted to facilitate the shower install and provide up to date protection. As said above, bonding may need to be looked at amongst other things.
Thanks Andy, and everyone else for such quick helpful answers.
Am off to bed now so won't see any further answers after this post until tomorrrow :)
Kev
I’d bet the same. Seems to be three grey coloured cables going into the bottom of the cream coloured ‘thing’. Two would be the tails, and the other perhaps the shower?
Worked with loads of these in the past, was even in one this week tutting and shaking my head. Admittedly the brown bakelite and metal versions are much more common round these parts though.
Metal clad with cover off
There is an estate of council bungalows near me and they all have these 2 circuit fuse boxes.
One 5a lighting circuit and One 15a radial for power.
All wired in black rubber cables.
I would recommend a full EICR
Reply to No fusebox or consumer unit? in the UK Electrical Forum area at ElectriciansForums.net
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
