M
Manchesterguy
Help!!!
After trawling the web for LED under cupboard lighting and getting totally confused, I thought I would join the forum to see if anyone can suggest my best options.
I have 2 runs of cupboards on opposite sides of the kitchen,each measuring 1.4mtr. At the moment I have a 221mm S15 LED 5w 250 lumens tube and a S15 LED 5w 360 lumens tube under each run which are connected to a mains socket by a 3 pin plug.
Ideally I am looking to replace them with lights which through out a brighter whiter light but are dimmable. I bought a 2mtr run of 3014 SMD LED lights which have a dimmer and are powered the same way. Unfortunately at 720 lumens they are not bright enough.
I don’t have a big budget although I am willing to spend upto £40 for all I need.
I would appreciate any advice you can give
Thanks in advance.
Thanks in advance.
