Discuss Old colours in the Industrial Electricians' Talk area at ElectriciansForums.net
O
optician
This may be stupid question, but here goes.
If you have a reel of old colour cable, unused (red, black, T&E), can you still
use it if correctly colour coded when installed?
In the interests of recycling etc etc.
Not 100% on this but think that as long as the cable is identified at its terminals then it complies with Regulation 514 of the Regs?
When you say old - how old are you talking?
You wouldn't want to install alot of it to find out that the insulation of the cable has broken down through age?
Personally, for what is worth I would just use new.
Thanks for your messages guys.
The cable is 5 years old approx and i have tested the IR and the resistance of each conductor and it's all fine.
As long as its identified correctly at every access/terminal point it's perfectly ok to use.
The only thing to be aware of is the need to label up at the CCU that there are more than one colour schemes in use in the installation...if indeed that is the case....in a normal situation the existing cabling is "old colours" and the new cabling is harmonised....what you are describing is the opposite way round.....I can't see that there is a difference as regards keeping to the regs.
Randyrat
Agree, but for relocating a couple of sockets or lighting i wouldn't worry too much, however, its really not good to use t'other way round.
Saves another label on the CU!!
Reply to Old colours in the Industrial Electricians' Talk area at ElectriciansForums.net
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
My FIL wants a cctv system at his house, and normally i would just go with whatever kit was on offer at the time from t'internet. My own system...
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
M
Hi Guys I purchased some of the above online around 3 weeks ago, They are a fairly new product, very usefull as you can change both colour from...
