Discuss Outside up light connection in the UK Electrical Forum area at ElectriciansForums.net
Hi, have some outside up lights to do (for a mate) currently has just run 1.5mm SWA come to look at the up light what would best way to connect it be? It has a pot to then you screw your light into but on drawing looks like I need adaptable box then some flex to light? I’ll post a similar up light to what he’s got as i can’t find his exact one.
[automerge]1582095665[/automerge]
That will be full of condensation/water in no time unless it is in very well draining ground. Not really possible without a lot of extra work
round here.
I only fit IP68 ground lights these days. Either way you’ll need a connection box underground - probably gel filled adjacent to it so you can connect your swa to a flex. Pratley or besa box or whatever
Reply to Outside up light connection in the UK Electrical Forum area at ElectriciansForums.net
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
