Discuss PAT Tester broken but i can use megger? in the UK Electrical Forum area at ElectriciansForums.net
Hello guys
my seaward PAT tester has given up the ghost, i have some small PAT jobs coming up and was thinking short term of being able to just use my multi function meter.
R2 test on class 1 equipment using low voltage ohm meter
Insulation resistance testing with leads
Trying to think what other limitations i have by just using my multi function test instrument?
I'm not certain what the current PAT testing consists of,but if the tests are possible using a calibrated MFT,i would assume it was OK.
There are earth continuity,polarity and IR tests,so an MFT would cover these. It is not a statutory requirement,so as long as any certification you provide,matches the testing you have done,all is well.
I was told.a long time ago,that you could offer PAT testing,as a purely visual only examination,providing the certification,stated this. Obviously,this does not example due diligence,too thoroughly,but would be legal.
OP - do the items you are checking actually need any testing? Most small appliances these days are class II and may only need inspection. Remember, the phrase 'PAT Testing' is misleading.
Also bear in mind the HSE guidance on the inspection/testing of equipment in low risk environments - there is a document available.
A lot of people are surprised about how little actual testing is needed.
As Westward 10 saysyou will miss the high current earth bond test, you will spend ages pratting about trying to get good continuity.
There are frequently Seaward Supernova Plus's for sale on ebay for ridiculous money, I bought another the other day for £25.22 delivered. Cracking tester if a bit chunky
If it's only a short term fix he may not need the high current earth bond test.
Many handheld PAT testers only produce 200mA “Soft” earth bond current. BTW, Portable Appliance Tester refers to the test meter being portable not the appliances ranging from handheld to fixed!
To be accurate, PAT is a non existent phrase. The correct terminology is ISITEE.
Portable is irrelevant as you say.
I find abbreviations irritating in general but the appearance of ISITEE is particularly annoying.
Yeah know what you mean Mate, unfortunately that's what we are given to work with, annoying for those who know the difference.
I know what you mean westy, but it's got to be better than PAT testing. That phrase perpetuates the myth that it is only portable appliances, and that is only about testing - when we all know that inspection is the big part of it.
i find it extremely annoying coz i never can get the "I"s , "T"'s, and "E"s in the right order. all the right letters, but.......
Yeah very good point, When I worked for the DOE/PSA we had a testing regime, "Testing Power consuming Apparatus" all those years ago and someone got it right.
I'll be honest tel, I had a quick peek at the COP to make sure I got it right!
Reply to PAT Tester broken but i can use megger? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
