Deleted member 138473
Hello
I am wanting to know if any one can help me with a question I have in regards to PFC.
When testing PSCC and PEFC in order to find out the PFC, so that this value can be recorded and then compared against the breaking capacity of the protective device, on what part of the system is actually tested.
The test takes place at the DB/CU on the incoming Line and Neutral conductors with the main switch off.
So this will measure the current from external side from the DB/CU to the star transformer ?
My query is that if my understanding above is correct then this is only testing the potential fault current externally and not the internal installation.
I would have assumed the potential fault current that occurs inside the installation on the outgoing side of the DB/CU is what is needed to be tested, as this where the fault would take place and that potential current would need to be compared against the breaking capacity to ensure the protective device had a greater ka than the Ipf.
I might have gone completely off track with this would appreciate some clarity.
Thanks.
Thanks.
