Discuss Phase Check in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've finished a PIR yesterday and am just going over the paperwork. I just realised that I need to go back and do a phase check on the incoming 3-phase power lines. I've told the client I'll pop back in to do it but he has asked if I will need to shut down the power to the building to do this, I normally do this on a dead DU on the live side. I have a fluke multi-tester, is the phase test a passive test so that I can do the test without cutting the power or will I have to cut the power to the installation to do the test ?
Thanks in advance for your replies
Andy
just stick your phase rotation test probes on with installation energised. it's a live test so no need to isolate installation.just try not to blow anything.
Reply to Phase Check in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
When working in a control panel. If I needed to replace a 3 phase contactor do I need to carry out a 10point check to prove dead on just the mains...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
What can be worse than electrical installations on a farm, or in a pub?...... Chippys! Got a phone call from my local.... Lights and kitchen...
