Discuss PVC conduit cutters in the Electrical Tools and Products area at ElectriciansForums.net
i use some with a trigger, similar to mastic gun, squeeze and blade advances . similar price from elec. center.
I've got a pair of Draper Expert ratchet ones which give a nice clean cut but they take up quite a lot of space in my toolbox, so started using the cheap ones from Screwfix, which seem to work fine.
I would steer clear of the big 'scissor action' ratchet ones which do mini trunking as well, because they take both hands to open and squash the tube as the blade gets blunt.
i use these... :)
:eek:Ah! post after my own heart
bought several pairs of cheap nasty scissor type ratchet ones from (CPC) and ..wasted my money. ended up throwing them away.
If you want to doa professional job you need the tools and £20 is not much to ask so bought a CK pair with lots of attachments and man they are superb.
Like a hot knife through butter. I have been using a hacksaw for years and I realise now how 5h!t that is. (Lenny I think you were jesting with your suggetsion:eek:
please excsue spelling beered up
yeah, it's called a knee, usually found between the femur and the tibia
Reply to PVC conduit cutters in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hi All. Stumbled across these conduit bushes from Greenbrook/Norslo. Where and how are they used/fitted ? GreenBrook B20 Conduit Bush 20mm...
Hi , Does anyone know an UK manufacturer that has 600*300*300 PVC or PP manholes? Thanks in advantage.
Has anyone got experience terminating steel conduit from 1935 (so likely imperial measurements) into a new metal enclosure? This was the work of...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
