J
jedbenson
Hi there,
Could i possible get someones views on this?
Weve had a new kitchen installed during which we decided that we would have an induction hob.
when we bought the hob they told us it would need to be on its own RCD in the same way our existing cooker was. So before the new units were fitted the put an additional 6mm cable thorugh connected to a new cooker switch and then cooker connection unit.
Also at the same time we buried this wire into the wall (concrete) fixed steel shielding plate over it and replastered. We also did the same for 2 other surface mounted cable runs and changed a couple of sockets on that wall from surface mounted ones.
Now heres where im told i now have a problem. I was going to get some quotes to have a new larger consumer unit installed and the new feed to the hob connected up to that at the same time.
Im now told by a couple of people i know that it cant be done and still confirm to part p regulations?
basically if i ask an electritian to change the consumer unit i will end up having to rip the kitchen out so he can put new wires in! is this true?
I would value some opinions on this before i go asking for quotes as i dont really want to get ripped off at all. It seems minor weve only really put a new wire in at the end of the day.
thanks
thanks
