Discuss Radiator power cable. in the DIY Electrical Advice area at ElectriciansForums.net
Red One
Hi, is it acceptable to extend the power cable to a wall radiator as in the attached picture. The cable was contained within plastic conduit.
It's one of these where it's 'safe', but not technically compliant. All live metal is enclosed with the cover off (not like there's an exposed bus bar in there), but there's single insulation present.
All it needs to be compliant is for the trunking lid to be made removeable only 'with the use of a tool'. There are some brands of mini trunking available that come fairly close to this as they stand, if you can't get a finger under the lid at the end, but a clip of some kind, over the conduit and fixed to the wall with screws will solve the problem for all makes.
Isn’t there a reg that states that connections inside trunking should be contained within a suitable enclosure?
or was I just imagining it?
I thought it just came under the 'need to use a tool for access' rule, but maybe.
Reply to Radiator power cable. in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Hi all. I've purchased a ceiling light. It has a very long power cable and an adjustable steel cable to suit the height you want it set at. My...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
What's best practice if running cable from garage out to outside double sockets? I'm re rendering that wall and thought it'd be nice if I could...
