Discuss Rcd tripping on new hot tub circuit in the UK Electrical Forum area at ElectriciansForums.net
I'm having a problem with the CU rcd tripping out, I have installed a feed outside to my daughters hot tub using 6mm cable about 14mts in length going to a metal clad dis board and from there via a 32A mcb to a 32A switched socket, insulation is good, no damp, but when I connected up the tub the rcd tripped, I removed the connections and connected a socket to connect a kettle as a test load everytime the kettle was turned on the rcd tripped, Ideas please tia
Is it a single 30mA RCD for the whole house?
A bit more detail would help. It might be just the leakage of the tub is accumulating too much for the RCD. Do you have a clamp ammeter (that can measure down to mA) you could check the leakage with by clamping both tails?
It could be a fault in the hot tub, given it holds out on a kettle. Can you IR test the tub at 250V (just in case electronically switched) to check that L+N to E is showing tens of Mohm?
Another possibility is a N-E short somewhere (not necessarily on the new circuit). If you are on a TN-C-S supply the origin N-E voltage is practically zero so typically that only shows up if you have loads of tens of amps or more. It might be the kettle at ~10A is not enough to cause enough N-E current to divert, but the tub coming on pump and heaters at 30A (or more, if motor surge is simultaneous, etc) is enough to reach threshold.
If you suspect a N-E short then switch off the main supply (so both L & N isolated at the origin) and do a global IR taking L+N to E, maybe at some convenient socket (having made sure RCD reset and socket switched on!).
Again 250V is safer to play with, but L+N to E should always be safe to test at 500V (unlike L-N on low power electronics where 250V is max to try just in case).
It trips on the kettle as well and that is 3kW
could it be a N-E fault on a completely different circuit, so that when a large load is applied on the new circuit, the RCD sees imbalance . had it before where a N-E fault in a shower switch tripped the RCD that fed the other half of a dual RCD board. time for an electrician methinks.
Reply to Rcd tripping on new hot tub circuit in the UK Electrical Forum area at ElectriciansForums.net
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
