Discuss Rear Fog light has made an mot fail in the Auto Electrician Forum area at ElectriciansForums.net
W
Wildrobot
hello so my rear fog light on my Mazda bongo has fail the mot due to not working.
The bulb is fine, I used a multimeter to find out it wasn't receiving power.
So I've rigged up a wire from the switch to the bulb socket but the bulb still doesn't light up.
I've now completely removed the bulb socket and tested it on the battery which lit up the bulb. Reconnecting my new wire and then either earthing the bulb socket or touching the negative on The battery doesn't work.
The new power wire is reviving volts, and the light on the switch lights up when the connection is complete it's just the bulb doesn't light up, I've tried different bulbs and get nothing
Is there anything else I should be checking I'm a total novice, relays? Amps?
Any help is muchly appreciated
measure resisitance between the lamps earth and the metalwork of the chassis. if below 1 ohm, then trace voltage back from light to switch with it switched on. sometimes a high resistance connection will show voltage when there's no load, but the voltage disappears when you put a load on.
You must have at least dipped headlights on to power the fog light switch up, have you done this. I am sure you have as the tester would have instructed you probably.
Where have you run the new cable from and to?
Hi: Go your local car parts place and buy a 12v test lamp (not led) & use that to test for power at the light, a multimeter (especially digital) can be way too sensitive & show a voltage that isn't really there. I.e a Ghost voltage, a test lamp will only light if there is useable voltage at the fitting.
I keep a test lamp in my car toolbox for exactly your sort of problem.
Reply to Rear Fog light has made an mot fail in the Auto Electrician Forum area at ElectriciansForums.net
The brake lights on my caravan (Sprite Swing) are not working, but all other lights work. I have tested the globes and both elements are working...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all. I'm new to this forum so thank you for having me. I'm having an issue with my bathroom lights. I have x4 MR11 3.5mm Spots. They've been...
Hey everyone, here's my imaginary problem, let's say I have 2 light bulbs, both of them take energy from the same source, however, 1 of them has a...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
