Discuss Replacing fused switch with Smart Switch in the Lighting Forum area at ElectriciansForums.net
In the hallway we have a fused switch that operates the towel ladder in the downstairs bathroom. Any possible issues in replacing with a smart switch? I don't know of any with an integrated fuse.
The above-suggested switch seems your best choice.
If you had to use one from a given family of smart switches for central control you could always fit a smart switch along side (and fed from) the existing fused one, if necessary changing it to an unswitched fused outlet:
https://www.NoLinkingToThis/p/mk-logic-plus-13a-unswitched-fused-spur-flex-outlet-white/29775
(The MK Logic ones are good and my own choice, but don't get the MK "essentials" range as they are rubbish)
Reply to Replacing fused switch with Smart Switch in the Lighting Forum area at ElectriciansForums.net
I can't seem to find the right answer for a smart switch installation for a light that has THREE switches. There's conflicting information, and...
I genuinely can't find a 3 gang 3 way black smart light switch - any ideas where I can get one from? Seems to be hard to get hold of?
Ok guys, first post so be gentle. I have a standard setup of two two way switches, one at the bottom of the stairs and one at the top so the light...
4K
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
