Hi, im wanting to rewire my garage lighting and replace the lights currently in there now.
At the moment i have a two gang switch controlling two lights inside and one outside fed from an fcu. At the other end of the garage there is an outside light on a plug top.
i want to replace the two light fittings for led batten lights and add an extra 2 gang switch at the other end of the garage so it can be controlled two way and have the outside light controlled by a switch rather than on a plug top.
I know i have to run a two core to the switch from the fcu, a two core up to the inside lights and a 3 core between the switches. What i need to know is how to wire the new two gang switch for the outside light that is currently on a plug top as there will be no neutral at this point.
