R
Robinson
Hi People, Interesting one today, friend wanted me to do check on 2 Circuits of his extension.
And he said LBC told him they would be happy to have PIR/EICR Considering it was 16th when he extended.
He done work 5 years ago ! which i thought was a odd thing for LBC to say, but they still asking him for it.
I clearly stated there no way he would get any other cert other than that .
anyway what he didnt tell me was he basically extended exsiting Ground floor Final Ring and Ground floor light circuit to his extension
1st i check out Lighting and he as 60! Lights in total on 1mm T&E all most down Lights max 50w each and few wall lights max 50 lamps.
But here's the bit, the lighting on a ring. 1mm T&E 10amp MCB RCD protected
End to end test showed was a ring and he was aware it was too . And in all fairness readings were sound.
WHole lot of non accessable JB's so would not be able to test many of points as earth stops at JB's.
fittings not require earth but still cant get to jb;s, there are other points around house switches/wall lights i could test.
But what im concerned about is how i go about recording this? As its a ring would i Still carry out final ring procedure.
Any thoughts.
Also got Final ring 2.5mm T&E with 60 points, biggest load is washing machine & underfloor heating , no ovens or showers. Its within 100msq. Say if test results are fine, any thoughts as too codes/recommendations on this. I mean i know its know to be unlimted but 60?
Hope You All well and good !
Any thoughts.
