Discuss Schneider 63a single phase switch fuse in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Has anyone used a Scheider 63a single phase switch fuse before?
Im just wondering whether they need crimped connections or whether its a terminal?
What’s with all the questions
you might be having you nails done or hair,lol.;)
[automerge]1567190403[/automerge]
Those MEM switchfuses have really gone downhill in recent years, I stopped using them a few years ago when they started coming with terminal screws that appear to be made from some kind of cheese.
They used to be good but now I'd rate the Schneider ones over them.
Reply to Schneider 63a single phase switch fuse in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
When there exists a single-phase transfer switch within a 3-phase distribution system, is it necessary for both feeds to the transfer switch to be...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
