Discuss Security lights upgrade in the UK Electrical Forum area at ElectriciansForums.net
stephennn
Hi
We've just moved in to a new house and it's got 3 outdoor security lights in the back garden. I've tried to trace the wiring back inside but I cannot find where it goes other than finding the ring that it's on. The plug (if there is one) could very well could be hidden under the attic insulation.
I'd like to replace them with lights with motion sensor plus a remote so that I can use them 'always on' .
Does such a product exist that is able to be retro fitted by a diy'er, would you be able to recommend one.
Could it possibly be wired rear entry into a socket? Is there a socket in a similar position inside to where the light is on the wall? If so as Midwest said be sure to add a fused spur
I meant for OP to have a butchers around his/her house, for an existing FCU, that might be feeding current luminaires. :)
Reply to Security lights upgrade in the UK Electrical Forum area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
