Hi All, I was changing a light fitting (something I've done many times before). Since it was a switched live to the ceiling fitting I had left the circuit still live (I know but no comments about that please!). Touched the neutral and got a small shock. So used a test screwdriver to see if the neutral was 'live' - it did show live for a few seconds and while I was doing that test another light on the same lighting circuit was flickering. However, after a few seconds the neutral no longer showed 'live'. Many of our light bulbs are LED (some 2 way and 3 way) and I did have an interesting capacitance related problem on another lighting circuit which was solved by using a different LED. Any suggestions please?
