Discuss SMA Inverters Data logging in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
provr6
Is it possible to store past data useage onto a usb stick or disc and delete old data from the inverter? If so how do you do it? Thanks
Simple generation data can be extracted from SMA TL inverters using the sma-bluetooth program, a compatible Class 1 Bluetooth Device and a Linux terminal console.
A simple command line script, ran via the cron command, could automatically append generation readings to a text file,
which could be manipulated into an alternative format using a variety of Linux commands.
This could be implemented on a Raspberry Pi, with USB port.
Dont know how to delete historic generation data on SMA Inverters.
Reply to SMA Inverters Data logging in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We don't normally do PV, however I was called to a PV inverter with no power, 6 years old Found supply OK, however fed through a AC type RCD. PV...
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
I'm exploring the use of Tradify for my business. I note they have the ability to import pricelist data in .csv format so that you can build jobs...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
