Discuss Spotlights in the The Welcome Forum area at ElectriciansForums.net
I assume you mean down lights, Ansell Orbio 360 downlights are nice at the lower end (still a good product) not the typical rubbish that can be easily found in some of the stores. Orluna fixed curve if you want something a bit nicer without the glare mid range area.
Reply to Spotlights in the The Welcome Forum area at ElectriciansForums.net
I'm looking for an LED spotlight that can be mounted on an existing lighting column. The aim is to illuminate a war memorial that is 20m away...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Hello I have 10 spotlights in a room. All 10 spotlights are operated by one switch. I would like to split the spotlights into two sets. First...
When a 20W LED spotlight of the same brand and design is added to a 5-meter single-wire track system, which already has four 30W LED spots...
