You say you have run your cables through trunking, is this one trunking with multiple cables in or have you run them all in separate trunkings?
What is length of run and size of cable used?
Because your doing this without seemingly without any real Electrical knowledge then how have you calculated what size cable to use, its not just a matter of running a given size because it says it can carry that ampage, your installation methods have derating factors due to the methods you chose and must be accounted for before wiring.
You cannot isolate the mains as the meter and service fuse are not your property so it would be illegal to do so, the correct method would be to tail up your new board ready to be conected into the meter and contact your Electricity provider about making the change over for you and re-sealing the meter and cutout.
As you are wiring new circuits, how are you going to test these circuits and write them up, the testing is crucial for the safety of yourself and family and may show up issues you were unaware of, its not a matter of it looks alright its essential you test before energising. Its great saving a buck or two but at what risk.
Not saying what you have done is incorrect so far but DIY should stop at changing light fittings and socket tops, when designing and wiring new circuits a lot of calculations and regulations have to be adhered to and its clear that you have been given a few basic requirements already that you were unaware of so Im unsure as to how you have designed your circuit ?
