Discuss Strange reading. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
Robo
Ring main.
End to end readings
LL 0.47
NN 0.47
EE 0.73
I calculate the R1 + R2 to be 0.24 however im getting im just get 0.00
ELI 0.44
IR >500
Would the low reading be due to parrellel paths as i cross connected at socket.
Thanks robo
When measuring (R1+R2) you have both disconnected from supply and cross connected at the CU so it can't be parallel paths mate. Top of my head I'd make the reading 0.32 ish.
I would re check your connections when cross connecting in a figure of 8 as you should be around 0.3 ohms.
What is the reading when you cross connect the line and neutral conductors?
0.47 + 0.47 /4 is what you should be getting at s/o on the ring!
Your loop test looks OK what is the ZE ?
I cross connected in socket which may have been foolish? I definately cross connected correctly. appolgies it should be about 0.3 ohms for R1+R2.
The ZE is 0.12
Iv been round with plug in tester and theres no cross connections. unless hidden in fcu??
The ZE is 0.12
The reason for cross connecting in the CU is so that you don't have the live conductors connected!
Reply to Strange reading. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Did a check on a ring circuit, due to board having to remain live I did it at a socket.. Was an RCBO, had checked RCD side and all tested ok...
Looking for some guidance here. I'm currently shadowing a guy and we're testing a new extension on a school. 3 phase TNCS supply from the original...
Domestic house, ring final circuit on an rcbo, end to end tests: r1 = 0.95 ohms, rn = 0.98 ohms, r2 = 1.02 ohms. It's rare a reading is too...
Hi All, Busy doing an EICR and on 2 of the Socket Rings for the dead test I get the following results: Step 1: End to End (0.32 ohm r1, N ) & (r2...
4K
My main tester is a Megger MFT1711, which I bought second hand but came with a calibration certificate. Rather than annual calibration, I have a...
