Discuss summer house supply thoughts in the UK Electrical Forum area at ElectriciansForums.net
been asked to price a socket to a Summer house , throwing it out their for any views which may help me decide my course of action , Ideally i would like to get back to the Consumer unit , but its virtually impossible without major structural upset , and can not go external from it either due to the nature of the property . So , what i do have is a Garage Socket , which i am assuming is from the current ring main , on a spur . I thought maybe fitting a fused spur into the line and going off the socket down to the Summer House which is approx 25-30 meters away and feed a socket for a reading light and small heater , problem is the distance and what amps i would have at the Summer house already from a spur , plus the size of SWA i would need , seems a mighty job for a Summer house which could not get further away from a source which is so hard to get to . Any Views ?
Bit worried someone asking these sort of questions are willing to carry out a job that requires notification. A registered sparky would carry out simple cable calcs to work out cable size AND identify where garage socket is fed from.
If you suspect the garage socket is fed by a spur off the ring main, why would you need another spur in line?
I'm with @KevinH post above.
You want to spur off a spur and run it 30 meters from a circuit that that you are not sure about.????
Please clarify you post mate.....
already i laugh , it was just thoughts , just asking views , and sorry no i do not crawl about in lofts to determine where a cable goes , but my assumption is the garage socket is spurred off the ring main like most extra sockets get done , of course i would check if i went any further , it is not already on a spur as in 13amp fused spur . I know full well i can ring up technical if needed but was merely asking views , as for certification hahaha , not many carry that out around here only the big boys , everyone misses that part of the job and saves a fortune ha ha wink
Not a lot we can say mate.
From your general outlook on things it looks like you will do whatever you want to do.
Crack on.....
This is one of the best lines I have read for a while:
...problem is the distance and what amps i would have at the Summer house already from a spur...
He/She has been making me laugh, so im happy if they carry on...
Hi welsiana,
If I was you I would start by doing the neccissary cable calcs for a cable 25-30 M. Taking into account cable type, if it's buried or not. Voltage drop, current capacity, Fault current etc..
I would then ascertain exactly if that garage socket is a spur from the ring main.
Then I would come up with a cunning plan.
Then I would call a registered insured sparky to do the calcs again and get him to come up with a cunning plan. Then I would instruct him/ her to carry out works at a cost to ensure that they cover there registration and insurance.
Then the sparky could sign off and notify building control in a professional manner.
Pete
plenty of time to sort it out. won't be needed till next summer. could use cat5. 2 cores= 3A, 4 cores =6A. 6 cores=9A. sod it , use all 8 and have the extra capacity up to 12A. don't forget the 13A fuse ( well, that's the closest to 12A). :eek::eek::eek:.
Reply to summer house supply thoughts in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I recently moved to an older property that had a run down garage. We had this removed and a summer house put up in its place. The old...
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
