I work in a production maintenance environment and have little domestic knowledge and have a question if i way about the earthing of the armouring of SWA. The question arises from my neighbours free solar install. From the invertor in the loft to the PV RCD in his garage the cable installed is 3 core SWA. The isolators fitted at either end are the MK type plastic enclosed isolators that i use at work for local isolation and lock off purposes adjcent to motors etc. Now the glands have been fitted with banjos as these can be seen and have nothing attached to them. Now i would without question always use a core as a cpc but would still earth the armourings as well. My system is being fitted in two weeks by thge same company and i would like comments from you domestic guys on this issue, reg quotes etc.
Also the test results sheets for the install lists the invertor as a sunnyboy but it is not is another type does this matter?
Many Thanks
Jon
Many Thanks
Jon
