Discuss Swerved a jod, am I being a bit soft. in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
Got called out to a commercial kitchen, the job stated that they had no gas as the intake fans had failed.
Turned up an the "local spark" had bypassed the Merlin CT1250 and effectively hard wired the gas valve, intake and extract fan and completely omitted the E stop.
None of the wiring inside the control panel was labelled so everything would have to have been identified and a new panel wired in.
The old panel had a failed PSU and relays, why?
Apparently it "went brown" within a few weeks of installation 6 years ago.
Why?
Was he original install cosier?
What am I getting involved in?
....drops shoulder and heads for the exit....
Right call?
Or need to grow a pair?
Did the "local spark" understand the implications of what he was doing bypassing the GAS SAFETY system as he obviously didn't understand why it was fitted
I would have walked at that point and left it to him to find the fault and repair it
Always check with your insurance that you are covered for this kind of work, as simple a concept it may be or seem this is a safety system that requires knowledge of the underlying regulations, these fall outside of the BS7671 standard, you even breath on this equipment and you become liable for the whole circuit and possible consequences of it failure to operate safely when required.
I dare say this would need more than a test cert and would require a full user manual and log book to keep records of all testing, alterations, repairs and faults etc but this is guess work as I don't have the relevant standards to hand and was just relating a commercial/industrial fire alarm system requirements to it been that it is a safety critical system.
In reflection here, walking away was a wise move.
Reply to Swerved a jod, am I being a bit soft. in the UK Electrical Forum area at ElectriciansForums.net
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
Companies like chekatrade, homeserve , BG and other insurance products exist because of the fear that rogue traders exist I recently called an...
Just a rant regarding all these landlords EICRs that have become the in thing. And maybe a word of caution to all of you doing them. To kick off...
12K
C
I apologise if this is posted in the wrong place, I hope someone can help me please to decide whats fair.. I asked for a quote from a local...
5K
