• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Switch for entire lighting circuit? in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Hi Alanm,
If you try to protect your light equipment and also electrical consume and if your electrical Panel have for security I.D. (Interrupter Differential) whom is also one for Lighting and one for Sockets then, you can use an Photo-Sensor (Crepuscular Sensor or another electronic photo-sensor) and electric Contactor connected in serial circuit of Lighting I.D. to electrical Panel. This will work Off for Lighting house in a Sun day and On for all circuits when begin the Night automatically. Also where is places in a house without windows (like a Bathroom for example) you can separate this circuits from electric Contactor to let them in old connection in electrical Panel and other's circuits what you don't need use in Sun day make a new connection to the electric Contactor. The Sensor will be connected in serial connection with Coil of the electric Contactor for command this Off and On. Also, you can call an Electrician with Autorization if you can't do this work alone.
Maybe leave him with some restricted form of control of a main room light ,( where others may be invading his space ).
Hiting a button shuts main lights off instantly for 20 sec maybe , then will lock out for 30 min . As it is a form of communication with others in the room .
(A magic trick he could perform ) .. Stressful if removed !
(Message form my wife who cares for autistic children and adults)...
What a brilliant idea static zap. I'll be getting Aldo (MrLights) to wire up something like that for one of my clients :)
Hi Alanm,
Whilst the words appear to all be English, they make no sense at all.
Try writing in coherent English, there's no time limit on how long you take to write a post so take it slowly and proof read it so that your posts actually make some sense to those who read them.
How about an overall timer for the lighting circuits so off during the day but automatically on for night (allowing local switching on and off) then an override to allow day use if needed.
Reply to Switch for entire lighting circuit? in the Electricians Jobs area at ElectriciansForums.net
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
