B
Bright.Spark
Ive recently installed lighting and power into a garage and might use it as my assesment for my part p. Looking at the test sheet where is says "method against indirect contact", would eebads be a correct method???? Thanks guys.
As of the 17th Edition as stated above its ADS , (Automatic Disconection of supply) .I liked EEBBADS but time moves on.
If it says that on the test sheet, then they, themselves, are 16th edition - best download some 17th edition ones if you're using it for your assessment.:)
Test sheet for garage supply
Bright.Spark,
WayneL,
