Discuss Test sheet recording Zs & Ze etc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
johntom
Hi
When I test R1+R2, Ze and Zs and record them on the test sheet, do i record the Zs (as measured at all socket outlets) or do i have to make it fit using Zs=Ze+(R1+R2) ?
Obviously the measured values will differ from socket to socket etc and the R1+R2 will be the highest on the circuit, so the Zs won't equal Ze+(R1+R2) what do i record?
Got my elecsa on Thursday and don't want to fill the sheet in wrong!
That makes sense, the sheet does say 'the highest measured Zs'. However when i did the C&G 2392 exam in february I was told to change either the (R1+R2) or the Zs, but can't remember which?
many thanks
Reply to Test sheet recording Zs & Ze etc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Evening everyone, I was taught when carrying out Zs testing to test both L-PE and L-N and record the highest result of the two tests for my Zs...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
So I’m doing my level 3 design project at the moment, and I’m on the question where you do all the calculations on each circuit, I’ve taken the...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Got my am2 coming up on Tuesday and I know I have to calculate my Zs readings Maybe I’m overthinking this but am not sure if I need to use the Ze...
