- Dec 18, 2011
- 5,378
- 6,731
- 405,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Evening all,
I am awaiting a reply to this quote (below). I thought it was about right, but perhaps too high. Would be good to get some opinions? Its basically a rewire plus extra bits for the bathroom, outside, smokes and loft.
£3120 if they move out. £3470 if they stay in.
I thought it was ok but maybe not?
Popped it in the arms as its about pricing which is good to keep a little more private!
Description of works.
Full rewire of property to include the following:
Living room
5 x twin sockets
1 x pendant light
Hallway
2 x twin sockets.
1 x pendant and 3 x fire rated downlights (fitted with goodquality LED lightbulbs)
Doorbell.
Ground floor closet
1 x batten light.
Kitchen
Change single socket to a twin.
1 x fluorescent strip light to be reconnected.
Reconnect up existing supply to all sockets/switches/cookeruntil further structural work is completed in 2016.
Dining room
2 x twin sockets.
1 x pendant light.
Bed 1
3 x twin sockets.
1 x pendant light and 2 x fire rated downlights in alcove(fitted with good quality LED lightbulbs). To keep pull switch in situ.
Bed 2
3 x twin sockets.
1 x pendant light.
Bed 3 (master bedroom)
3 x twin sockets.
1 x pendant light.
Landing
1 x pendant light.
Airing cupboard
New cable to fused connection unit for immersion heater
Bathroom
Supply and install new towel radiator with standard timerand isolation switch located in airing cupboard.
Supply and install Fan heater with isolation switch incupboard.
Supply and install extractor fan with isolation switch located outside bathroom either above/right of door or in airing cupboard.
1 x shower (10mm cable to be used) and pull switch to berelocated.
1 x shaver point.
5 x fire rated and waterproof downlights (fitted with goodquality LED lightbulbs).
Loft
Install loft light.1 x standard batten light with pull switch located in loft near loft entrance.
Outside
Supply and install 1 x LED floodlight for back garden, switched from within the house.
Supply and install 1 x LED floodlight (with sensor) for parking area.
Supply and install 1 x LED floodlight (with sensor) for front of house.
Other
To remove all old fuse boxes in kitchen and replace in ground floor closet with a single Dual RCD 17[SUP]th[/SUP] Edition Consumer Unit.
Supply and install 2 (linked) smoke alarms, one on ground floor and one on landing.
Additional information
All switches/sockets/pendants supplied will be of good quality, either Crabtree or MK. They will be standard white fittings.
All new cables and points will be channelled into the wallor hidden in cavity walls, any plastering work to be done by a plasterer.
All downlights will be fire rated as suggested by the Electrical Safety Council.
Total Cost = £3120 - £3470 (depending if lived in)
Living room
5 x twin sockets
1 x pendant light
Hallway
2 x twin sockets.
Doorbell.
Ground floor closet
1 x batten light.
Kitchen
Dining room
2 x twin sockets.
1 x pendant light.
Bed 1
3 x twin sockets.
Bed 2
3 x twin sockets.
1 x pendant light.
3 x twin sockets.
1 x pendant light.
Landing
1 x pendant light.
Airing cupboard
Bathroom
1 x shaver point.
Loft
Outside
Other
