First off I am not your matey and wouldn't want to be I based my opinion of you and the others mentioned not only after your comments to my post but on others I have read on this forum over the past 6 months.
I have read my posts made in this thread and still claim I have never said 200 ohms is an acceptable value for any TT installation if you want to use my reference to BS 7671 to try and justify your behaviour towards me then why don't you just refer to 1667 ohms also mentioned in BS 7671 which in theory is the maximum.
If you think any customers are willing to pay an electrician to mess around trying to achieve an Ra to gain ZS values which may never be achievable you are mistaken not in my part of the world where TT is the dominant method. If you have a two up two down mid terraced property supplied by overhead no PME with a tarmac pavement at the front and a 6 inch concreted yard at the rear you are limited to where rods or other methods can be used you do your best to achieve the lowest Ra you can in a timely fashion.
Don't put it right next to the wall!
this is probably going to be obvious, but really check for services before banging an 8 foot spike into the ground, as water pipes and drains etc are only at about 4 foot, and it can really ruin your day to put a spike through one of them.No it's ok I won't, I was just saying the existing one is next to the wall. I spoke to Trev and said put it a clear meter away from a wall min, which is a good idea, I need to have a look to see where I can get one in and see where's best.
I do appreciate all the advice given.
I was going to say that 1m wasn't far enough, but thought I'd check, and apparently it's actually 750mm minimum depth for water pipes in England at least. I'm sure I remember being told it was 1200mm, but that might have been Scotland, as I can imagine in Inverness or somewhere 750mm isn't going to protect from winter ground freezing.Where accessible it's always advisable to excavate a down metre, before driving the rod(s) in the ground if there is a possibility of pipes or drains in the vicinity. Also makes setting in the flush earth connection pit that much easier too!! lol!!
When I was doing festivals, one of the stage crews put a spike through the mains water pipe that just happened to be running randomly through the middle of a field without the farmer even knowing anything about it being there. Not what I wanted to see on the morning before we opened, a sodding fountain slap bang in the middle of the front of the main stage.
Been a bit paranoid about it since then.
twas a 5 foot marquee peg to guy the stage cover down.'Singing in the rain', eh? or 'Three coins in the fountain', maybe.......shouldn't have been much trouble sinking the rod, at least.
