V
Vessy
Hi, need some advice on a TT earth path.
House has CU in hall and a smaller CU in garage which is supplied with 6mm T&E from a 32A MCB in the house, the earth rod is connected into the garage CU then the cpc from the 6mm routes this into the house CU, is this OK or should I get the rod connected direct to the house CU?
Everything protected by 30ma RCD's as required by regs for TT, the only other observation was garage CU earth connects to gas pipe (in garage) & house CU earth connects to water pipe.
Thanks.
Thanks.
