Discuss Two consumer units in the UK Electrical Forum area at ElectriciansForums.net
Two consumer units and meters. One pair for a flat above a shop and the other set for the shop. The armoured cable rising diagonaly above the consumer unit ajacent to the building electric supply feeds the the shop meter and consumer unit in an other basement room.
It makes me laugh when spark come on the forums and asking about the jobs they do are doing or going .
Say your other half comes in with a dress and its tucked in there nickers
And you about to go out would you say
You look nice or would you say you are only half dressed .its a s&&t job.
Rather than use a new bit of earth cable because the old one is 6 inches too short they just grab a bit of 15a connector and ‘ add a bit ‘
Nice work
Nice work
The armoured cable is a roller coaster run. There is plenty length to connect an uninterupted earth. The cable is salvaged three phase where the yellow has been used as an earth.They were too lazy to cut the sheath back .
Unless I am wrong Buzz the O.P. is a plumber maybe his from the other side and sees the forum of sound advice. Why his reasons for asking is another matter.
There seems to be a general lack of understanding of how many layers of insulation need to be on cables, and how to attach them to the wall. And various other details.
Reply to Two consumer units in the UK Electrical Forum area at ElectriciansForums.net
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
