Search for tools and product advice,
Discuss Unidare Storage Heaters WMS718N in the Central Heating Systems area at ElectriciansForums.net
N
Neilos
Not really a CENTRAL Heating problem but heating none the less.
I have a customer who has Unidare storage heaters installed in her property. The one in the hall doesn't seem to be giving out any heat despite no changes to the controls recently leading me to believe that something is a miss.
It is on the E7 supply and I've checked the supply to the unit is ok.
I've also checked the voltage at the base of all three elements and there is 240V to each element.
I figured that if the voltage is there surely the elements should be heating up thus the elements are faulty, but I'm now doubting myself after reading threads about other storage heaters pointing in the direction of the thermostat being the cause.
Has anyone had any experience with these as it's the first time I've had to fault find on them.
Any guidance would be appreciated.
Carry out the usual basic continuity test through the various parts of the circuit and then measure the resistance and IR of each element to ensure it is going to dissipate the correct power
Reply to Unidare Storage Heaters WMS718N in the Central Heating Systems area at ElectriciansForums.net
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
I recently got my flat rewired. It had old storage heaters and we plan on putting modern storage heaters in. The way the electrician did the...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
