Discuss unistrut lighting system in the UK Electrical Forum area at ElectriciansForums.net
Unistrut can have a cover to the channel fitted. Not sure I would call it a lid.
Unistrut is perfectly fine to carry cables that do not need mechanical protection of steel trunking.
ie. swa, or equivalent…...I've done that, no prob
You can get a plastic lid that clips over the unistrut channel....if that’s any help?
You also get steel lid for unistrut.....and stainless steel 'dairy grade' lids as well.
I also regularly use it as containment for both cables and singles wiring, not sure why there'd be any advantages to using truking over unistrut or why unistrut wouldn't fit the bill admirably as containment.
Fair do's....but I use the original strut for fixing to, generally with spring nuts, which obviously prevents using it as a cable route.
If I use it as structural support ie bolted to a wall with cantilever brackets and spring nuts then no, I wouldn't use it as containment in those circumstances.
Suspended from a factory roof with fluorescents fixed to the underside....yep, containment.
Call me a cowboy images.jpg I don't care :cool:
Maybe wrong, but I would doubt it's bs standard rating for carrying single insulated cables. Much stronger than trunking, yes, but what about bushing, locknuts, bends, etc? It's not made for it.
There's nothing in our local regs preventing it being containment if it's installed accordingly but the UK regs may well not allow it.
There's no pre-formed bends as such, corners and tees are made by hand using a variety of winged brackets bolted on the backside of the strut.
Just a thought, are they singles in the unistrut @rockrose ?
If so then 521.10.1 requires IP4X containment for all non sheathed wiring. Might give you an argument to do a proper job.
That's my whole point, Neil. I presumed the wiring indicated was just that.
Before I done some research I would have insisted in rewiring in FP200 or similar.
However I have just checked an unistrut does conform to BS 61537 that is the Standard for wiring systems so it would appear that unistrut is suitable so long as it is installed to manufacturers specifications.
Every day is a school day.
yea thats what i want to do but the factory boss wants use the unistrut to save money on trunking and time
So the Factory Boss has no concern fro the safety of the Factory workforce, are you a member of any of the CPS schemes? if yes call the help line for advice, me, I would bin the idea of using the Uni strut as containment, if he won't budge on his demands then you may need to walk away.
Can you quote any reason why it wouldn’t be used? I don’t see no issue with using it as long as it had the correct lid.
As you said there is no cpc in this circuit, or have I got the wrong end of the stick?
Reply to unistrut lighting system in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
