Hi, apologies if this is a daft question to ask but would really appreciate some advice.
I wiped a light wall switch in the hall with an anti-bac wipe (dettol kind, so fair amount of wetness from the wipe unlike the cheap kind that can be fairly dry). When I wiped it, I accidentally flicked the switch on, light came on and I switched it back off. The wall switch covering was definitely wet, not in the sense that I’d chucked a bucket of water over it but it definitely was wet to touch. I didn’t realise until I walked away that the light wasn’t going off properly. It was flickering and staying on. Zero problems with it until this happened. When I tried switching it on/off again I got a tiny electric shock - or what I assumed to be electric shock, though it’s a plastic covered wall switch. I left it for about an hour and tried again, the light switched on and off as normal.
Should I be concerned about this and get an electrician to look at it? I’m worried I’ve wrecked the wall switch and even though it’s functioning normal it could still have a fault. Or do you think I’ve just been a bit daft and wiping down a switch without drying it before switching on, and somehow the excess water from the wipe had caused this and all is fine now it’s dry and operating normally?
I have an RCD fuse box and it did not circuit during this.
thank you so much for any advice in advance!
