Discuss What is this about? "littlenergy"? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Shooby
Hello again.
Is there anything more to 'littlenergy' than just fitting a battery to your PV system? Does it have the potential to 'earn' you more than just the savings from storing unused leccy for use, say, during the evening or cloudy days?
(I tried to post a link to littlenergy, but the forum thought it was spam. It's a 'com' website.)
This Q is not directly connected with my other PV question on here - tho' I guess it could be. I have a 16-panel (3kW) PV system myself but with no battery, and I was wondering if it would be worth having one fitted.
Many thanks.
Thank you, Spin. I hadn't thought of that...
Assuming that the FIT (which I was lucky enough to get at the max rate) is unaffected, what is a typical cost of having a battery installed in order to maximise the use of the captured power?
And is there anything special about 'littlenergy'?
Cheers.
Reply to What is this about? "littlenergy"? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I currently have a 3Kwh solar PV system which was installed over 12 years ago and getting a very good FIT payment and I don't want to lose it! I'm...
4K
Is it ok to have PV system into shared (household) RCD? So I've had a system installed, but not yet complete/signed off. The issue is that the PV...
8K
I currently have solar array and was going to purchase Shelly EM to monitor Grid in/out and solar production. So far so good. But I also plan in...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
