Discuss What the low down on GET consumer units. in the UK Electrical Forum area at ElectriciansForums.net
I think Schneider ended up with GET, but they only seem to make switches now - So only old stock or second available now - about £10 a breaker from here.
Reply to What the low down on GET consumer units. in the UK Electrical Forum area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
