Sometimes I read comments from pub members and think really? Then again it's Friday and you are allowed to talk nonsense.
A high percentage of neutral earth faults I find are caused by cables in sockets etc being squashed against the box entry with no grommets in sight.
to say you don't need them is a bit wrong as they have been about in their current form since at least the 70s.
i prefer grommet strip as its a better fit and doesn't fall out unlike the ****e grommets you get these days.
stay away from niglon strip though .it is terrible
Grommets are only used really for 1st fix to prevent to cable from scraping on the box, once fitted there's little point in them being there. If you are carefully feeding the cables in to the back boxes and not pulling them down some capping or something then I wouldn't bother with them every time.
Have you tried the tapered super grommets. I find they are easiest to fit and don't easily dislodge when you are fannying on getting cables through. Much better then the standard ones.
Personally, I find a thread about grommets to be a refreshing change. :sleeping:
Aye Geordie, it was nylon machine screws a few days ago and pin plugs a few months ago. Reckon grommets deserve a post too!!
What's next I wander; staples, best shotgun clips, catenary wires....
Maybe it should be about 'no grommets'. Came across this today. The earth sleeving had melted and was solid on the wire...which just dropped off. Shows just how important they are.
View attachment 28485View attachment 28486View attachment 28487View attachment 28488
Look carefully and you can see some red pvc near the end of the earth wire.
One bleedin' good reason to totally dismiss the comments in #7
And there was me thinking that the cable sheath should pass through the knockout with or without a grommet being present into the back box. I'd say that the damage to these conductors is a direct a result of bad stripping/termination and arrangement of the cables within the back box, Especially with all 3 cables passing through a single 20mm knockout... Obviously a grommet would have helped, ...well maybe!! lol!!
Aye, maybe:smile5: and every top and bottom knockout removed. It wasn't a dead short....nothing blown, hence the heat effect....and with all the blackening, it's obviously been getting pretty warm. The only reason for removing the socket was to find the supply to an outside lighting controller...so two 4mm's for the ring and a 1.0mm for the lights, straight to the control. Lucky they let me look for it... would have been paying for an unknown internal wall heater.....'till it blew :icon12: ...among other problems.
My NIC assessor saw I had written C3 on an PIR (in those days) for lack of grommets at accessories and told me it should have no code, unless there was damage to the cores. As the bonding plaster would hold the cable in and stop it from chafing.
I hope you corrected him of his misunderstanding
which grommets are you talking about? the blind grommets we use are crap and fall out if you just breathe near them but the open grommets are fine
[h=2]What would you do - dodgy builder[/h]
I'd tell him to Fokker Off.
After asking him which reg is being not adhered to.
Is this really worthy of posting, a few missing grommets
Is work quiet, why would you even get involved with this?
its really surprised me that a builder knows what a grommet is as ive never come accross one yet that has used them
For me it was worthy of a post as some plantpot has tried his best to slander my business. Between us sparks a few missing grommets might not be the end of the world but to an unsuspecting customer who's being told she can't sell her home because of it it becomes a big issue! The more I've thought about it the more furious I am. He's blatantly taken grommets out to try and score points.
I've told the customer Under no circumstances will I be second fixing her extension.
